jpatter123
well I am wiring everything up and was curious on where to ground the mags. All my negatives on the boat run to a bus bar (just the way I prefer to wire). A buddy came by tonight and said run your mags right to the bus bar and at first I was confused because I thought I needed an earth ground to ground out the mags. But after further thought the bus bar runs to the negative terminal on the battery which goes right to the motor block so its a combination earth/negative ground , correct? If this is right then it should work or am I going about this wrong? I orignally was going to ground right to a stringer on the hull figuering this would be the best earth ground but its not a great 12 volt negative ground. its an all aluminum boat.
Also what size should the ground wires be? It looks like 8 AWG coming out of the mag and 14 going to my switch. But the ground side the guy had it with what looks like 16 or 18. I was going to replace this with 10 AWG. Is this unnecssasary? Thanks.
