I have a couple of intake lifters that have started knocking at idle. The knock goes away at around 1500 rpm. Since there is no adjustment, I'm guessing that I need to replace the lifters. Is that correct or is there something else I should do? Also can these be replaced without removing the cylinders?
Thanks
Thanks
