C Capt Jeff Well-known member Aug 23, 2007 #1 Had some issues with the workmanship on my c/f prop which is now back & the factory. I was lent a 70x42 that came off a 0540. My boat is a Hamant 14x7 with an 0540/290hp. Can I get by for a night or two with this set-up? Thanks!!! CJ
C cont520 Well-known member Aug 23, 2007 #2 wide blade or stick prop either way you should be alright
hmgm123 Well-known member Aug 23, 2007 #3 That a bit on the small side, most 0540/290 run 72x42 to 72x46 range. Be careful not over rev it too much.
C cont520 Well-known member Aug 23, 2007 #5 I would be very care full like hmgm said you will probably snap the guts out of it
R Rich Andrews Well-known member Aug 23, 2007 #6 normal operation fine....gator huntin(adrenaline rush) don't over rev!
