HELP! GPU
plumcrazy
any body tell me how the frikin heck you get the bolt out of the back side of the assesserycoverdown low behind the oil filter its around a corner in a hole got to be some kind of trick to it or im just stupid signed stumped :evil: :evil: :evil: :evil:
Are you talking about a 220 GPU or a Lycoming O-290 GPU? If it's the 220 GPU, do you mean the two bolts that hold the accessory case on inside the magneto holes. If that is it, you need to bend down the keeper tabs first.
Sorry, I can't help on that one. It's not a through bolt is it? Good luck. I'm sure someone will have the answer. Take a picture of it.
the PE90 accessory's case is the same as the 220 (pe-150) the two bolts that hold it on are under the mags
what are you trying to take off ? you can get to that oil pump once you remove the case
Vary carefully :violent1: I've got the tool to get'er done... :D
