Help Lycoming flywheel
bustsducks
Active member
Hello i am hoping you guys can point me in the right direction. I'm looking for a 149 tooth lycoming flywheel. It doesn't have to be new a good used one will work also. Thanks for your help.
you can replace the ring gear on the fly wheel real easy. Cut the old one off. Place the new one in the oven @ 400 for 15 min & put the fly wheel in the frezer for 1/2 an hour . Drop the ring in place & let it cool.
