Well here is the problem. I have new cylinders,rings,pistons installed on my 220 gpu. I still have high oil consumption, so I pulled everything off again. I noticed a lot of oil in the cylinders around the piston skirts and under the pistons. So I'm thinking about oil spraying from the rod bearing is getting into the back of the cylinders. This could be causing the cylinders to be drowning in oil, something the rings can't handle. So I pulled the rod's and I have .008 of play, I think it should only be about .001. Now just to cover any questions everything has been checked and double checked (tolerences) on the cylinders,pistons,rings ect. Now anyone have any thoughts on this? help me please.......... my head hurts!
Rick
Rick
