Adam, Cut from the palm of each hand up the inside of each leg
front and back, then straight down the belly to connect these
two vee shaped cuts ( >-< ) don't try to skin out the hands and
feet cut it off at the ankle or wrist, Split the tail about half way
from the anus to the tip on the bottem then very carefully peel
the carcus out of the hide turning the tail insideout as you go
slow and easy making small cuts as you go. as for the head, cut
straight up from between the front legs to the center of the
lower jaw about an inch from the bottem lip. At this time every
thing should be skined but the head. start pealing the hide over
the head being carefull not to rip thehide when you get to the ears
cut them off below the hide then trim around the eyes and right
down to the mouth cutting the hide loose between the lips and the
gums. Almost forgot the nose, when you get to where the hair
stops, cut the nose off under the skin.
Much better to leave the hands, feet, nose, and ears for the
Taxidermist ( he wont mind ) than to slip and mess up your
hide. Kevin.
