MarshGator
What’s the best method to determine if a used hull is straight and true? Looking at an 18’ Aluminum hull with engine stand, cage, and some of the rigging.
I believe the hull side slid into something and bent (compressed) the u shape t-bars that run from side to side. Two T-bar side supports that run across the hull are unbolted and not connected to one side. On the trailer the hull looks straight, but I intend to get the hull flat on the ground to see if it still looks straight. If the hull looks good, I believe it would only require two new t-bars supports to replace the bent (compressed) ones.
Any thoughts or comments?
