Bowhntr6pt
I have had my airboat for over a year now and quite comfortable with it. I have run deep/shallow water, on grass islands, and LIMITED dry ground. I just can't seem to climb over small mounds or bumps from the start.
This past weekend, I ran the Withlacoochee from the outlet NW. I ran across a dry patch that was maybe 40 yards long consisting of mud and sand, but it looked quite solid and dry. It took just about everything I had to keep going. I have tried to climb small dirt mounds after watching other boats do it but I can't. I have seen boats pulled up on the river bank or lake shore and have always been weary about trying it as I don't want to bother folks to get me un-stuck.
I watched one guy climb the ramp at the damn, and although he did have to "give it hell" some and spin about some, I don't think I could have made it. Thinking back, I wish that I had flagged him down and asked him to wait to help me if I got stuck.
So I am thinking really hard about making some changes that I can afford. Getting a new set up is TOTALLY out of the question.
I assume that it would cost less to switch all my stuff (motor, rudders, tank, rigging w/alterations of course) to a different hull in an effort to reduce my overall weight factor, which I think is my problem.
Or is my thinking flawed?
I have a 13x7 Airgator hull with poly, poly is in good shape, no problems there. I have a 0470 GPU that has about 27 hours on it since total rebuild. The motor is strong and I see no problems there. Prop at present is a wood "stick prop" 72x38. I know that I could/should upgrade to a carbon prop but for that cost, somewhere around $2500, I could get into a lighter/smaller hull and have better performance, or not??
I feel that I have a great boat, I just want to be able to go up and over stuff like others do, I want max push as speed is of no interest or importance to me.
I often see smaller hulls for sale between $500 and $1000. So my question is this... what would you do? I don't care if I have to bolt my motor to a trash can lid... I want lighter weight so I can join others w/o being a pain in the ass.
What say yall....?? What type hull should I look for, what size, etc??
