Daddy Dave
At last weekend's FAA meeting , FWC / DLE officials put out the warning to all airboaters, specially those with hulls marked "Homemade" to have Hull Identification Numbers (HIN) properly and permanently displayed on the starboard (right side facing forward) corner of the transom.
This number is listed on the boat title and MUST be permanently affixed to the transome of all motor vessels.
Do not assume that a hull manufactured by a company has this number affixed as required. Many hull manufacturers are mis-informed that VIN / HIN are not required unless the boat is sold as a complete rig. FWC / DLE position is if the hull floats, it requires a VIN. If it does not float when purchased and significant work is required to make the vessel hull float, a HIN is required. HIN Numbers are required on all vessels titled as 'homemade". Their position is this number VIN or HIN must be permanently and legibly inscribed into the hull or a number plate must be permanently affixed to the hull.
They warned FAA that VIN / HIN inspections would be done on all airboats stopped for any purpose on Florida waters. This, they said, is proimarily in response to the ongoing rash of airboat thefts.
