I’ll try to keep this short but not sure if I’ll be able to : I’ve been lurking around for a while, trying to make the most informed decision I can on a boat purchase. I worked for a company for over 20 years that had two air boats and did small jobs for customers (company mainly did terrestrial weed control) I resigned/retired at the end of last year and started my own company. I landed a sizable contract that is going to require an airboat a couple of months out of the year on a large private property. Mainly spraying invasive plants at a mining facility. I don’t need to go fast, but I do need a lot of push to get through some of the heavy vegetation. For power one of my main goals is reliability in a When I left, my previous employer had a couple of Alumi techs With 383 power plants, belt reduction. Our first boat was a Combee fiberglass hull custom built for us with a ground power unit. I spent a lot of time on that boat and it always seem to carry the weight of the water tank well. I found a used hull, stand and cage that looks nearly identical to the one I operated so many years ago. I guess my main question is are these:
I’ve got a 383 short block that suffered a detonation episode with only a few hours on it. Two pistons now have breather holes in them. Crank will need to be turned but everything else llooks good. It’s headed to the machine shop today. If everything checks out, aluminum heads or iron? Carburetor or Holley sniper fuel injection?
For the drive, I’m most familiar with the belt driven reduction units, or with the gear style be more reliable? Assuming I can get 400 hp from this motor, any recommendations on prop for a working airboat application?
Thanks in advance!
Thanks in advance!
