i agree with d.b. putting longer push rods will only stop the noise but the valve will not operate correctly. the valve will stay closed longer and not opening all the way, prob. causing overheat issues at the very least.. not a good combo on the motor. definitely robbing you of a few of those ponies we are all chasing!! (all of this only pertains to automotive motors, but should still apply.
Marvel mystery oil can do wonders to bring back a stuck or collapsed lifter. again, at least in auto application. don't know if compatible with ashless a/c oil but if so, put so drain 1 qt and replace with m.m.oil. let her run till she good and warmed. sometimes if you dont drain any just add to it (dont leave overfull) so it brings oil pressure up and somtimes will help unstick. drsin oil and refill and ride out!) if not, well maybe somebody else knows some other trick without replacing GOOD LUCK!!
