NightRider
Hey guys, first time poster here on Southern Airboat and I have an issue with an 0540 I just had mounted on my first boat. First off, let me say that this site and the advice contained within has been a huge help for a newbie like myself. I plan to add some of those red stars above my username shortly.
I recently purchased a 300 upstack off of another boat, and at the time of purchase the engine sounded good, has decent oil pressure (5o-55 lbs. cold idle), and was priced right.
After mounting the engine, overhauling mags, and adding new headers we fired her up to discover it had a stuck valve. I immediately took the boat to an A/C mechanic who performed a leak down test and a valve job on the appropriate cylinder. The leak down test revealed that I only have good compression on 3 cylinders.
I don't remember exactly but I think the readings were 70, 68, 60, 48, 45, and 30. Not really a big deal because I don't mind having a top end job done. But, here is where I run into a problem. When the mechanic pulled the cylinder he said he realized the engine is not a true 300 angle valve because it lacks some kind of injector for the high compression pistons. He believes I would be better off to sell the engine and start over than to overhaul the top end and tear into the lower end to install the injectors. Apparantly what I have is a 260 case and 300 jugs? Anybody have any advice, could I put on 260 jugs and be done with it? I would prefer to salvage/fix what I have.
Thanks again SA and regular contributors who make this such an excellent site!
