yellowboat
Been hanging around the edges of this southern airboat and I have learned a lot. I have a 13 x 7.6 diamondback airboat with a zz5 350 short block rated at 385 hp, magna flow mufflers, all aluminum rigged, stinger 2:1 belt reduction,spinning a power shift 78" falcon blade. The motor tach's out at 5,000rpm, but I do not have any speed. Boat runs with GPS at about 45-48 mph. Boat has poly bottom and pushes dry ok, could be better. Like every airboater I want it faster and quieter with tons of push.
Wanted to throw this out and see what type of ideas the gang would recommend to pump this boat up. Long time watcher and reader first time writer.
