goldhunter_2
JohnC,
thanks that helps out allot I measure again when I got home the back bars will be fine but I will have to move the oil cooler it is about 1/2" inside the blade pattern.
On that other thing I did some quick figures on 5052h32 .90 aluminum (1.256 per sq ft) with 24" holes would weight 30.144 lbs plus 1 lbs welding wire plus 4" sides weight 5.024 lbs making the total weight 36.168 lbs let me know when ya'll start I come down and give you a hand
Thanks again,
Robert
Thanks again,
Robert
