Me wanting to get the best performance out of the type of engine and hull I have, probably like everyone else. After years of knowing that the 3 blade IVO wasn't getting it. After asking question and getting different options. I finally decide on getting a 3 blade Sensenich. I installed it and ran it up a couple of time and made some adjustments. I decided to take it out and make the others on the water. Well after getting started I could not get over 1500 RPM at times and some times I would get 2400?? Anyway after messing with the prop all day the RPM was still the same. I thought maybe toooo much pitch not enough??? I than thought it might be a carburetor trouble since my boat has set up almost a year. I only had it out 3 times( something wrong with this picture) anyway I took it to Jurnigans, he has gone thought the carburetor and thought it might have a cylinder with low compression. One was a little low and he found out one of my rings wasn't seated.$$$ Now this boat ran great with the IVO it just didn't have the speed and push I knew this rig should have. Back to the story Now Jr thinks with this prop its the harmonics that is causing the engine to run this way. He is putting the counter weights back on the crank. $$$$$$
Got the boat back now all I have to do is finish setting the prop.
You might want to re -THING making your boat get the little extra you are looking for.
I think it's like Bigdaddy says Any times it runs brake out another thousand!!!
