marshmaster pat
Helping work on a Lycoming 0-540. It was giving some kick back as well as running alittle rough. Checked compression and all 6 were bad (lots of hours on it). We did a top end job with some help and fired her up. The magnetos had alot of drop in them, so we stopped the run in process and the mags were rebuilt. Installed them and tried to fire her up. Kicked back hard on the first try, busted in inside gears in one of the new flush mount $tarter$. Ouch.
While it is getting redone, we started at TDC#1 and checked out everything. Timing is all ok and set right. ???
Could a battery with low Amp or volts, have enough juice to turn that Lycoming part way over and then cause kickback?
Ideas anyone. Never had this problem that was not an issue of mags being out of time. Looking for other things to check on while we wait for the starter.
Thanks
Thanks
