I bought a used rig a few months ago, my problem was a 45 degree impulse,( :shock: ), (instead of 25 degree), it would impulse at 20 degrees past TDC when set at 25 degrees, (ineffective), so when starter spun it fast enough it would crank like a straight mag and kick back sometimes. I've had an impulse hang up due to condensation in accessory case. Found wrong impulse with timing light, in fact, I've allways used auto timing light for final setting of mags, you can find mag problems sometimes at higher rpms.
A trip to Lacy Everette solved problem. :wink:
calbrigsr, if your timing is correct, you have a non working impulse. Turn it thoough by hand and listen for clicks with mags off!! The impulse could be intermittant due to crud buildup. They need to be pulled and checked by a mag man.
