North Idaho
Any assistance is appreciated - opening weekend for ducks was yesterday. Boat was running fine, was cruising for about 30 minutes between 4,000 - 4,300 RPM AND all of a sudden it just dies. Cranked for a few seconds and nothing. Removed the gas cap, took off the low pressure fuel line etc. boat fires up and idles fine. Get it back up on plane and it does the same thing when cruising, but this time it did it within 5 minutes. Ended up just running low rpm ( 2,000) all the way back to the launch with no issues. All temps were rock solid, oil pressure was 50-60 psi. by No means am I a mechanic, but it’s appearing that maybe the high pressures fuel pump isn’t supplying the right amount of pressure or perhaps one of the filters is clogged or ????
engine has 150 hours on it. i would assume a normal mechanic isn’t going to be able to tap into the diag port and see if any codes popped.
any suggestions?
thanks,
sean
any suggestions?
thanks,
sean
