Ragman2156
I have a 11’6”X6’6” air gator that I’m thinking of keeping light and I was looking at these 80hp Limbach engines, would those work as they weigh around 140 lbs or would that be under powering the boat
As far as I know you have to source them directly through Limbach, I’m just playing hell trying to find a lycoming that someone doesn’t want an arm and a leg forI think that doubling the weight with a 4 cylinder Lycoming and getting double the horse power would make you a lot happier on a 11 1/2 foot boat. A Pe 60 GPU would give you 90 HP.
Where do you get parts for the Limbach?
Never heard of Limbach Flugmotoren until now, but the offerings on the website look like a typical 4 cylinder boxer aviation engine. I see versions up to 125 kW (167 hp) at 86 kg (190 lbs), which is competitive with a Lycoming O-320.As far as I know you have to source them directly through Limbach, I’m just playing hell trying to find a lycoming that someone doesn’t want an arm and a leg for
