Looking for a used prop
webfoot1
Active member
Hey guys....
I'm running a 16x7 Marks hull being pushed by a 350 DD set up. I love the hull but it's time to upgrade the stick prop to a composite one (70 inch florida paddle)....then maybe a gear box when I save my pennies a bit.
I use the rig for goose hunting (mostly on ice) and just want some more punch. First off, does anyone have a prop idea that would help me gain some low end punch?
Second.....does anyone out there have a used composite prop they are looking to sell?
Third, how much difference do ya'll think a prop will make?
got a 76 inch WW prop 2 blade brand new perfect application for your needs...they sell for about 1800 new will sell for 1550 with 50 going to SA...
Wow Rich, that was quick. I just pm'd you about it......
How do you think that DD set up will swing that 76 incher?
Webfoot,
You would do better with the 72 Signature which is what is recommended for the 350 DD. 76" is a LOT of swinging mass for your setup.
Bob
I believe, if I remember, you have a PowerPlus set. Am I correct? On the serial number it will start with PL if it is. If so, that will be good for a small block with a belt drive if lefthand rotation.
Bob
I have a 72x30 wide blade from Florida Airboat Propellors that i'm trying to sell. It's not a composite prop but I used it on my DD 350 and it's just been reconditioned so it's like brand new.
