Fanboatman
I'm new to this site and to airboating. A friend of mine and myself have been restoring an old airboat (1983). It's a 12'X7' welded aluminum hull with a Lycoming 0320 and a wooden prop (can't remember the specs on the prop). It's almost finished except for the instrument panel. We've never driven the boat or even ridden in an airboat. Just wondering if anyone out there has had any experience with the 0320 and this size boat?
I completely rebuilt the engine so it should produce the rated 150hp. Any idea's on how fast it will run? The guy we bought it from said it would do around 45 to 50 MPH. We installed Poly on the bottom, will it run dry ground? Up here in Maryland the dry ground will be mostly dry gravel and some packed sand with rocks and gravel. Thanks in advance for the help.
