Welcome to the addiction! :toothy7: Lot's to learn.
I assume it is carbureted? I take it you have an electric fuel pump (mounted on top of or below the tank), but you likely also have a mechanical fuel pump mounted on the front accessory housing (see pic). The purpose of the electric fuel pump is to prime the system, but the mechanical should pull fuel through the electric once the engine is operating.
You also have 2 mags, the STBD side mag should be the "Impulse" mag that is used for starting, the right mag is typically not the impulse type. This is the aviation standard, but it might be different on yours depending on what the prior owners did. With both mags off (see safety info below), if you turn the prop by hand, you should hear a clicking sound every so often, that is the impulse activating. Figure out which mag is making the noise and which switch it is connected to. When operating, both mags should be timed together at 25 degrees BTDC. But, at low RPM during starting, the impulse mag has a spring system that holds the timing back to fire close to TDC for easier starting. Once running this system stops due to centrifugal weights and timing reverts to the 25 degrees advance.
If not installed, add a mixture adjustment cable before running, it is a safety feature, see below.
Procedure is:
- #1, always check that the prop is clear, no one behind boat, no dogs etc...!
- Mixture adjustment to full rich, normally push the cable knob down
- Electric fuel pump on, wait until you hear it load up (a few seconds).
- Hit starter button
- Turn on Impulse mag only
- Engine should start, if not repeat above but add a pump or two of the accelerator to feed some fuel
- Once running, turn on PORT mag
- Confirm oil pressure
- Turn off fuel pump
- Let engine idle and build some temp before putting the hammer down. Usually idle up after a few minutes of idle to build heat.
Safety
The magneto ignition is designed to fail in the running position, no one wants their plane to stop running in the air! To disable, the magneto P lead has to be grounded, this is what the mag switch does. In the run position, the switch is off, in the stop position the switch is on to connect the mag to grounded. This means that a bad wire, switch or ground connection can result in a live mag - the motor may start if turned over, all it takes is one bad mag ground (2 opportunities to fail in the ON position). It also means that when turning the prop by hand there the potential for the motor to spring to life! I have also had a situation where a tree branch broke a mag switch, same thing, I could not turn off the mag.
This is where the mixture adjustment comes in. Normal running is at full rich, but to shut down, do not turn off the mag switches, particularly when hot, the motor may run on. Pull the mixture knob to the lean position. Motor will still idle, give it several seconds and it will stumble, then press the gas and the motor will shut down due to insufficient fuel. Then turn off mag switches. Always leave the mixture in the lean position when off, it prevents run away in the event of a "Ghost" start.
Also, aviation carbs are designed to revert to Wide Open in the event of failure of the throttle return spring. I use 2 springs for this reason, inspect yours. In the event of a WOT runaway, the mixture adjustment is your savior.
If for some reason the mechanical pump fails, you can turn on the electric to feed the motor, but figure out why the failure occurred and resolve first, otherwise you will likely burn up the electric in short order too (hard lesson on my part).
Also consider dual start switches, one latching (or a key switch), the other momentary, so it takes 2 switches to fail to crank the starter.
Always turn off the main battery switch (big red Perko) or disconnect the battery, before entering the cage. Never turn the prop by hand unless ALL plug wires are pulled, or you are trying to hand start the motor and you are prepared for the result. Treat the prop like a loaded gun!
I probably missed some items on the safety list, there are a few threads on the board covering it in more detail, do some searches on "Airboat Safety." Others will probably add.
Stay safe, have fun. Don't be afraid to drive it like you stole it, these things are more likely to sink off plane.
