Kwan is correct. Without knowing what pistons are in it then you wont know for sure. Most likely it will have 10207 pistons in it. They are 8.7:1 compression. If that is the case then I would guess 290 to 300. That engine from Lycoming came with 7 or 7.5 to 1 pistons because it was turbo charged. I have had 2 of them in the past and love them. If it was fuel injected with 10:1 pistons that would make it 310ish HP.
More than just compression. My 540 was low compression in the 7 but the motor tag was 315 @3200 a geared motor. It has a good thump to the cam. Originally came with twin ma5s, So hp may be off a bit if only going by compression.
