Jim - I believe there was a fairly large online discussion on a similar article about 2 or 3 years ago. There is a great Lycoming Yahoo site for pilots, owners, and homebuilders that is ran by a builder with a very great reputation.
The Lycoming Yahoo group had a several weeks of discussion on it as well. While several of the builders that contribute to the discussion agreed, there were a couple from very well known aircraft shops that said while the oil delivery system is not a good as it could be, it is sufficient enough to do the function that is needed. Almost all pointed that there is a potential issue, the issue is not a problem if CHTs are closely monitored and ran on the low to mid range of recommendations. They all pointed out that many people are trying to run as lean as possible, with CHTs getting near the upper maximums to conserve fuel. Running an engine that costs between $25,000 to $50,000 new and they are trying to save $100s a year in fuel was foolish in their opinion.
This was especially true since most claimed that the range of CHTs could be as wide as 40 to 60 degrees. And since quite a few aircraft monitor only 1 cylinder, if it was a cooler one and you are running lean with CHTs set at near maximum, you could easily smoke a cylinder or cause valve issues.
One builder claimed there might be another issue. He claimed that the mold process that Lycoming uses on the cylinders, tends to allow some of the fins below the spark plug to have slag blocking the cooling channels. It was his thought that this, combined with low oil movement, would increase temperature enough directly around the valves to cause issues. He claimed that it was not uncommon for them to get new cylinders in with these ports plugged with slag/flash. They would grind them open and had no issues with motors since starting this.
However, there are some adaptors that are being sold to help increase oil movement this area of concern.
Good Article, Thanks
