Making room for 80” prop
Kbrewer
My hull is a 13 foot combee, it was setup for a 540 and a 74” prop, I’m modifying it for a 350 and gear box and with that being said there isn’t enough room to sling an 80 inch prop, I have 2 options, one is to make a low engine stand and cut out splash well or option 2 keep splash well and raise the cage, And also how far into the hull should a prop spin
