Icom is one of the best of the import radios. They have a great rep. They also make the sets sold under sveral other names.
Uniden is anolther one thats likely the best bang for the buck.
In this day of SMT assembly and electronics there won't be much technical difference in units cause they will all pretty much use the same chips. Most will have Wx A, or the whole range of 5 Wx channels. Features like a PA are worth having as is a foreward/refected power meter. Though analog meters are being ditched in most radios now days.
To work the best, your antenna will have to compete with your white light for the highest point on the boat. Both white lights and antennas take a beathing up there, but that is the best location.I have seen citations issued because folks had the antenna outside going up at the top of the cage and whe whitelight inside the cage. It's is of course an idiots game but they got the power to write so the law says on the highest part of the boat and inside the cage isn't the highest part of the boat. Small minds but oh well.
Remember most folks dont run radio suppressing ignition wires on their airboat engines so if you add a radio you may need to change the plug wires. The double insulated coax will drop the rf static that the coil and generator create as well as the real static generated by the charge build up from hull moving through the water. If theres still a whine or you actually have a generator instead of an alternator you may need a noise suppressor on it.
Use at least a #10 wire for your power. It works best if it is the only wire to the battery and not routed through other switches and connections. Same for the radio's negative or ground wire. Bigger is better.
Lots of folks mount their radio under the operators seat cause it shields it from rain and impacts. Sure isn't very convenient to change channels or any settings in this position. If an insturment panel is being made from scratch I like it right in the panel. I don't think Id hang it off of the outside of the panel, thats looking to get drug off by a tree or whatever.
Back when I was flying I had a SoftCom intercom unit that I could run the radio with a PTT (push to talk) button on the rudder stick and a headset for me and passenger so we could talk with eachother or I could use the radio. We could both listen to the radio but only my mic would be transferred to the radio if I pushed the PTT button. With well padded or noise canceling headsets it all worked great on the airboat.
Some of the antennas or maybe even all of them need to be tuned to the individual installation. This requires a forward/reflected power meter or a good field strength meter. Trimming the antenna is tricky since if ya go too far its difficult to add that last little piece ya cut off back on. Some have slip fittings so you dont have to be exact with the cutting you can cut for the best length when in the center of the coupling then adjust the slip to peak that last little bit of power. Reflected power should always be 1:1 but some of the shorter matched antennas will never meet that. 1.5:1 is about the best ya can do with some of them.
Remember on a boat you don't have an actual ground, so you can't use a car type antenna. Everything has to be grounded together with the largest wire. I like #10 multistrand for the grounds. If you have a metal hull use the hull as the common ground point, if not you may have to add a metal plate that will be submerged when underway.
Airboats are somewhat unique in that they can be under way and dry as a bone. Theres no real solution. Reception and transmission needs a good ground but proper marine antennas will help 'cause they account for the lack of ground in their design.
Make sure all the metal rigging is bonded to itself and to the common ground. Use the little brained cable pieces just like a car does, even though theres a bolt there and it all measures contenuity on an multimeter, still bond everything with the little braids, and I mean everything! Points often missed are rudders and rudder control sticks all need to be bonded across the moveable joints. Anything metallic should have a ground bonding point put on it. These wont prevent operation, they quieten the background noise so you can hear those weak signals.
Now thats the "short" course hahahahahah
Scotty
