OK now I see what you were getting at MarshGator. Your 100% right too.
Ok the distance from the rudder stick pivot (fulcrum) to the point where either the teleflex cable or the rudder rod attaches is the key to slowing things down in the steering department. If the steering is too quick it can be slowed down by DECREASING this distance in small increments. Say an inch or a little less at a time for teleflex cable steering. The idea of course is to have a lot of motion at the top of the rudder stick and a little motion at the cable attachment point. I like mine really slow with a maximum amount of travel at the top of the rudder stick.
A caution here of course is that you can get it too close to the pivot and then lose full swing of the rudders. They still need to be able to be moved from stop-to-stop with the rudder stick, without the attachment point over centering. Always make sure there is extra length on the rudder stick past the attachment point here. Overcentered rudder elements at any point in the linkage can cause a severe crash for the newby.
Converseley to shortening this connection point, you can at times LENGHTEN the point where the teleflex cable attaches to the rudders (depending on where and in to what part of the rudder it attaches). As stated above, small increments. Here maybe no more than 1/4 - 1/2" increments. It's usually so cramped back here thet you may only have room to make one change, but it is a place to look for space to modify. There are several different attachment methods back here so one set of directions or explanations won't fit all.
As with anything else on an airboat before begining to modify anything, what is there already must be in good condition and working order to begin with. Make sure all pivots, links, cables , holes, hardware is in excellent condition before beginning any modifications. Sometimes boats get squirrely just because the mechanisms are so worne they allow no real tactile feedback of input coorrections. Sloppy attachments are an accident looking for a place to happen.
Hope this adds a little light on where I was headed even though I was misunderstanding your original comment.
Scotty
