papee
A little info first. I live near Harrisburg, PA. My rig is for fishing in very low water at spots, well, of course I don't fish in the low spots(only a few inches).
I chose to go with a small engine, an 18 hp B/S twin cylinder. This setup take much less water when floating in the low water. Right now I'm using a wooden prop I made and will soon change to a CF three blade prop. The boat is a 16x6 alum.
Today went out fishing for a while then decided to experiment with the prop angle. I started out with it at a right angle from the stringers which was not the best, it ran better before. It will plane out if I find lower water. I'm staying in deeper water for these experiments.
First I adjust it using a thread rod setup I have on the rear of the engine to raise or lower the rear higher or lower than the prop side of the engine. The boat seemed to work better coming close to planing within about 20 feet. it came up pretty level but then the front end lifted and would not come out of the water.
Next I lowered the back end or pully/ pullstart side to keep the nose down. That setting was worse, so I deciced to adjust it to push down on the front and lift the rear. This setting was worse than the rear just slighty lower than the prop side.
I am thinking that if I get the best adjustment with this prop it should be pretty close with the new prop. My thinking is that with this prop, the adustments are easier to tell than when the new prop is on.
I'm looking for your ideas on which would be the best way to adjust to keep the front down or am I at my limit with this setup? I would like to get the most out of this setup before going to a larger engine adding more weight.
Sorry for the book but I wanted to give as much info that I could.
