Changed the plugs to Autolite 386's, cleaned the terminal ends all the D16's were black with one haveing some carbonized oil, but still fireing.
Mag was rebuilt and the impulse is "clicking" the PO went to great lengths to time it @ 28 degrees. The impulse "clicks" about where where it's at now in the picture. I presume TDC is the mark just a little further to the right.
The problem is RPM's and "sputtering" on the trailer you can rev it up to ~2,700 rpm but in the water you can only turn ~2,500 and it seems to spit & sputter, almost like it's starving for fuel, altho ignition can give the same problems...seems somewhere there was a thread or two about timing: of course without a manual it's hard to know the proper specs. and the PE90 should be able to spin the AirProp 66LXL34 to at least 2,800 rpm's
I think the problem is the fuel line: it looks to be 1/4" or maby 5/16"
A new 3/8" fuel line will be installed a soon as one can be fabbed. BTW: The carb is a new, 2V Holly from an AB parts supplier.
