Sorry to ask so many questions, but searchs have been less than fruitful:
What is the oil capacity?
Brands/weights of oil (remember it's cold up here!) PO was using Mobil 1 (weight un-known).
Oil filter? (saw an illustration on Durracan's web site but that was it)
Viewing the case from the prop end, on the left is a shaft sticking up that's slotted like some sort of linkage attached (see the bottom illus. on this link) http://www.dgsupply.com/d89.html Any enlightenment? when I first looked at the boat it had wicked high oil pressure, ran it a couple hours Sunday and it was anywhere from ~20 @500rpm to as much as 80 @2,200: Normal?
Any specifics on what used PE90's? The shop I work in has a library of thousands of Military Technical Manuals, but you have to know the modle of what you're looking for ie: M998, Truck, Cargo, HMMV
From everything that's been posted, it would seem that these are very durable, less than sensitive engines, and while it's not an AC engine, I still want to take care of like it was one. (Paddleing home sucks!)
