crowhater
My boat runs flat in the water and I need to fix the problem. If I put weight in the rear of the boat it runs much better but still runs flat. I have dual trim tabs so I can trim the nose down if I need to. The problem I have now is that the faster I go the ligher the boat gets in the rear and it will spin out on me. Once you hit around 40MPH the boat starts to feel unstable with no load. If I have 5 guys and 6 dozen decoys I can run up to 50MPH before the boat starts to feel unstable. It is 18" from the back of my boat to the back legs of the engine stand and 61" from the center of my hub to the bottom of the boat. My boat is an 18X7 with side by side control seats and a front bench seat. I run a 50gal fuel tank under the motor as well as dual batteries. My trim tabs point almost strait up unless I lower them so they do not make drag. I can attach pictures if anyone can tell me how to do this. If I change the angle of my motor will this make the boat stop plowing the nose? The motor is mounted level right now.
