Without knowing the condition of either motor it is hard to say which of the two is better. But both are 470 cubic inch. The aircraft version will always be the better choice. Even in a run out condition they were still built with certified parts. GPU motors were government overhauled. What we do not know about your two motors is are they both fresh built motors, or are they old motors that have been run for years. The main problems with the GPU motors is that they were all steel bore cylinder barrels. If it is in original unoverhauled condition the cylinders are usually rust pitted and wore out. The only way to get them back is to bore +.015 or chrome them back to standard. They also have a real low compression piston. By the time you add up a starter kit, second mag, holley carb and intake,chrome cylinders and hi compression pistons you can usually have a lot of money tied up in a GPU. The 0-470B is a 240 hp motor ready to go. The GPU is around 170-180 hp stock. I would choose the aircraft version.
