HuntOnTheWater
I recently just replaced my flexplate I am running a 383 stroker with a ch3 2:1 reduction. When I attached the flexplate to the drive plate with the 6 bolts and spacers I torqued the flexplate bolts down to 35 lbs and I am still able to spin the bolt in the hole by just turning on the head of the bolt. So i put probably 12 hours of run time on it like that and torqued it to 40 lbs and can still spin them by the head in the hole. Is this normal or should I look at getting some new spacers and bolts? I also ran it wide open toward the end of the night and had some pretty good wobble at 4400 and up rpm was wondering if this was the cause of that as well?
