jdotson
I have read that header evac kits will not work if mufflers are installed unless you put the tubes beyond the mufflers. Has anyone done this yet and how are the hoses plumbed? I can see it working if the exhaust crosses under the engine stand with the mufflers beneath the engine but if they were run straight out each side that could get pretty nasty looking. I suppose you could put the mufflers anywhere using exhaust pipe instead flex pipe and mount them close to the header? Just some thoughts looking ahead at the airboat sound issue. I'd rather work on it now than later.
