My 5th Airboat
Des Moines Boater
Well, I took my fifth airboat out for its maiden voyage on the Des Moines River yesterday. This boat is a 13 foot Lazer with high sides and a PE 150, 220 GPU, with a wood 72X32 wide blade prop. I was very impressed with the power and ride.
Even though the boat has a heavier engine, it only sat about 4 inches in the water. My 6 foot wide 10 and 11 foot boats with 4 cylinder Lycomings sat about 10 inches in the water. I got on plane quicker than anything I've ever had and it only took about 2000 RPM to get it up. It cruises a little over 30 MPH at 2000 and at 2500 RPM it really moves. The previous owner said it would turn up to 3200 but I don't think I'll ever see that unless I get stuck.
The only drawback was the boat is bigger than anything I've ever had but it handles well and I'm sure I'll get used to it. I have IO-470 cylinders and mags coming for it to convert it to dual plugs and dual mags. It looks like the conversion will run close to $1000.
I did cut down the seats, so, the boat looks a little different now.
Yall must have short sawgrass up there, or is it that
the frogs are smaller and you got to get down lower
to see them. Just kiddin sounds like a great boat have
fun and stay safe.
