Waterthunder
My Redneck preliminary sound testing. I have been pushing my higher gear box ratio theories for years now. Every person who has gone to my 2.68 combo has loved it the 2.38 works great too. They are shocked at what a low RPM they cruise the river at less than when they ran a 2 to 1 ratio box However I have been swinging the prop’s at a lower RPM than the prop manufactures are recommending but running a lot more pitch. Present combo is a 2.68 ratio with a 78inch Power Shift turning 5,800 RPM max this gives a prop speed of 2,164 RPM far below the recommended RPM. Here is a break down of the velocities!
Prop Diameter, inches Prop RPM Rotational Velocity, radians/sec Tip Speed, inches/sec Tip Speed, miles/hr New Diameter New Rpm@Constant Tip Speed Reduction Ratio Motor Rpm
78 2200 230.4 8984.7 510.5 78 2200.0 2.68 5896
Funny thing is this set burns up the hill and waxes other boats swinging much more RPM. This is not a theory I have proved it so many times I don’t care to anymore. Anyway here is another plus one of my gear box theory. A customer of mine has a 550HP motor set up this way with mufflers and when he rides all you hear is the gearbox howling, see the gearbox make more noise than a muffled motor or a prop turning at cruising RPM. The noise issue can be resolved but nobody seams to want to do it. Well now I now why but it’s not an issue, it once again reverts back to everyone’s fear of running a high ratio box. Anyway I'm Borrowing a DB meter and will start doing my own sound testing. Then hopefully at the next FWC test I will just show up and see if they will let me participate!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
