Robby Bondurant
Okay, here's the deal. I just got my boat done, I got all the valves adjusted, and set my 5 blade warp drive prop at 10 degrees each. I put it in my pasture today and tried to see what it would do.
When I tried to run it wide open it would only turn up to 2100 RPM's at the most, and I know that's not right. 10 degrees should not be too much for that engine at all but i changed them to 8 degrees each and that didn't change anything. The engine was running nice and smooth but it just wouldn't turn up.
When I tried to turn it up it wouldn't even budge, even with my buddy pulling on the front. But I know it wont let loose until I get it up to more RPM's.
I was just wondering if adjust ing the carb (the fuel/air mixture) would help this out? I'm thinking this is a stupid question but I just wanted to ask the experts. If this is what I need to do, how do I know when I have it set right?
Any help is greatly appreciated, thanks, Robby.
___________________________________________________________
I know I will probably get asked what kind of boat I have and all so...
12'8" by 7' glass hull with a dd sb 350 bored 30 over with a roller cam, edelbrock intake with a edelbrock 650 carb.
