Bit on the lean side, not sure what Demons come with out of the box, 31 squirter is fine, order gaskets for the bowl and metering plate, order a power valve plug, order a pair each of # 74-75-76 jets.
Ok, that said be very sure that the accelerator arm has zero lash to the pump and cam and it squirts with very little movement of throttle arm.
Double check mag timing, TDC #1, back up the number of teeth on ring gear equal to starter pinion gear count, that will get you to 25° +/-
Remove sight plugs on mags, bevel tooth shall be in center of window, if not, they should be re timed, also depending on compression ratio, may need to drop it back to 22° if still stuttering on wide open throttle, go with one step at a time.
