No real reason. I heard NAPA gold is the same as WIX (or Hastings, I forget) and that's supposed to be a high quality filter.Smugglers Blues":127rhod5 said:Just curious.. Why don't you like the AC filter for that motor?
Is HP-4 the part number for the ZZ383? If so, I'll just pick up one at Wally World.Olf Art":1gj691dd said:I run the Fram HP-4 ....... it gives you nearly another quart of oil capacity.
olf
Yes, I got it at Floral City. It has the GM heads.Smugglers Blues":2ewlxiyc said:Airduds question for you.. Did you get your zz383 from Floral City Airboats? If so what heads does it have on it? Are they the GM fast burns or Eldelbrocks? Just curious..
I got the HP4. Fit right up. I wanted the AC 932 because it holds two quarts but advanced auto didn't have it in stock.Smugglers Blues":3k2pumz8 said:If you pick up the HP-4 check the threads as well.. I thought on the zz motor the threads were different. Well maybe not the threads but the whole size. I didn't try the HP-4 but I did try a couple other Fram filters that fit SBC and the hole size was different so I stayed with the AC.
I thought the AC filter was the best?? Because it has the 12 micros?? I do know the manual recommends a AC PF25 but that filter is no longer available they changed the number to PF 454 and I get mine a Autozone for less than $4.
What are the micros of the Fram?? If it's a better filter I am all for it!! Let us know what you find out..
