Ok, so, I figured that I would elaborate a bit, the hull pictured "thank you for the compliment by the way!" Is a 6'8"×11' built from 7075-T6 aircraft aluminum, which only comes in 4' widths and 12' lengths, the sides are bent using a 14' press brake with a 3/4" round top die and a v block bottom die, the rear is bent at 8" and the front at 13", giving the hull 5" of taper per side.
That said, you can do this with 4' material with a seam up the center, order a length of 1.5x1.5x3/16 T-bar for center stringer, there has to be a place around locally that has a brake to bend the material, bend the sides 11" at rear, 16" at front to about 80° this will give you a 6'2" bottom at rear, cut T-bar to 9'10-1/2", bend it to match your rake pattern, leaving 1-1/2" from rear.
Take the remaining T-bar, cut an 8' piece, this will build your transom rail. Once sides are bent, center stringer welded in along with the rake up the front sides, I will walk you through bending transom T-bar after this.
