John C
I picked up my new hull from Hamant and dropped it off at c chardts place so he can start on the metal works. It's a 15x8, side by side front operator and triple rear. Chris is going to build it with 3/4in square tube. any suggestions or changes I should be aware of before I start the build? I plan on moving the radiator a little farther foward than my last one to allow for better air flow in front of the prop. I am planning on two sets of jacks. I have heard that some of the bigger boats have three jacks. Is there an advantage to a third jack on a 15ft boat? What kind of fuel pump are most of the Caddy guys running.? I was running the stock mechanical pump with a nappa electric fuel pump inline between the fuel filter and the motor.
