hello boys and girls, Well we had some excitement this moose season, some injuries, some damage and sunk my boat in a high silt glacier river. Water levels were way above flood stage for several weeks so couldn't attempt to recover the boat, finally the water went down and winter came on.
We took snowmachines and got to the boat, used chain saws to cut it out of the ice and by brute force and awkwardness managed to get it up. Started to pull it over the ice to try to take it home and the ice broke 13 inches thick, and down it went again.
We got it up onto the river bank high enough so that it won't damage the hull and left it till spring time when we can go in by boat and wash out about a ton of sand and float it downriver to the road.
So, engine is shot, 350 Chev direct drive to Hartzell pusher prop. Seat mount, prop cage and some motor mount damage.
Now the questions, more power would be good but I don't really want to go to a reduction drive, this is an old Panther boat and is really low in the transom so lighter would be better. I could go to a 454 but that's more weight, I could go to a Vortac V6 but that requires a reduction drive to get power so doesn't really save any weight.
If I could find an LS aluminum block engine that would be great but would require computer controls and perhaps the prop would not fit and the motor mounts might be different.
Or, I could find another old 350 truck engine and just put it back like it was.
What do you recommend???????
