Mohawk_Aero
Just a "HEY THERE" shout out to the forum. I just joined today, and don't know a cotton pickin' thing about airboats. I am ready to learn, and want to get started on a project right away. I live in Columbia, SC. Looking for a boat that needs a motor, in the 150HP range. I am going to install one of my Yamaha YG4 150HP aircraft conversion motors on it.
My webpage is www.MohawkAero.com and my email is info@MohawkAeroCraft.com.
I make PSRU (propeller speed reduction unit) kits for 4-cycle Yamaha snowmobile engines, have been since 2011. I have gearboxes in inventory with bolt-on engine adapters available for Yamaha RX1, Apex, Nytro, and Vector snowmobile engines. The geargox prop flanges are for all popular props, 75mm, 100mm, 4 in., and SAE1. I am a dealer for Warp Drive and Luga props. We use 66" to 72" props on our gyrocopters, and up to 84" on fixed wing aircraft.
My Yamaha YG4 kit puts out 600+ lbs thrust, not boosted. All-up installed weight for this liquid-cooled, carb or EFI, 4-stroke, 4-cylinder engine with exhaust, radiator, starter, oil tank, electrical system (less battery), gearbox, clutch, adapter, dry but otherwise ready to run is 165-175 lbs.
We do not use belt drives. We have, however, made a HY-Vo chain drive that works great.
I recently sold some YG4 kits to some airboat guys in Alaska, and decided I should get into it in my own backyard. Why should they have all the fun???
What should I look for in a good, used airboat for my YG4 kit? I don't want a fixer-upper, I want a worthy boat that I don't have to tinker with.
Thanks!
GT
Thanks!
GT
