New Rudders
dudley
I have a new set of rudders. I need to to know which is the best way to go before
I have my vinyl graphics put on them
1. Spray painted
2. Power coated
and where around Tampa would be the best place to have it done.
THANKS
Dudley
Before you powder coat-check with the dealer and explain your rudders are foam filled (they are aren't they?) I believe they will not powder coat them because of the heat temperature of powder coating.
my local powder coat guy puts 2 coats on them and it dose not matter if they are foam filled.
i do powder coating you have to drill a hole in one end top and bottom and poor gas into it till the foam runs out then powder coat them then buy great stuff refill them ad some jb weld to fill the holes your done if you dont empty the foam in the oven the foam will react and grow and your rudders will be round and or will break the welds
