Remember that Lycomings are aircooled. You are getting massive cooling compared to an aircraft, and typically you tempertures will be much lower at standard operation ranges. If you install a shroud and it is not correctly installed, your Cylinder Head Temperatures will skyrocket very fast, especially if you have to push the throttle hard for time. You can smoke a cylinder really fast. I know at least 20 0-540s around here in a 80 mile circle, all operated in different ways by different people and none have shrouds.
If you are concerned about CHTs, then you can set up a CHT gauge for around $150.00 for one cylinder. Change the probe from cylinder to cylinder, find you hottest one and leave the probe for the gauge attached there. Then you can monitor the Cylinder Head Temperature ranges as you operate. I found it educational.
Waterthunder suggested a temperature gun, type you point and get temperatures from. If you know someone you could borrow from, that would be cheaper than both.
Only saw one shroud on a Lycoming, and it was configured by a certified A&P mechanic to keep the temperatures within the Lycoming recommended ranges, around 180 is what they were shooting for. Worked great at cruise around the lake, but when they had to hit the throttle and maintained high RPMs, the temperatures skyrocketed. They changed the engine and rigging to a auto motor, due to the thinking there was something wrong with the motor. I got the shroud, the motor went cheap. Motor is still running fine and at the low end of the normal operation ranges. Wish I would have had the money at that time?
Look at small airports of 100LL fuel, that is where we get ours.
Enjoy that new boat.
