Hello forum. I am asking the same question as the previous post, but I will be a little more specific. I am wanting to build a mini myself. If I can't build it I don't want it. Part of the fun. I will be using it to run a river. The river has about 2 miles of deep water before you get to shallow areas. I will need a boat that could get on plane with about 700 lbs. of load. I will only use it to hunt. The access that I have to the river is through a friend. Therefore, I will have to take him and his dog in order to get in. I have a dog as well. We are both around 225lbs. and our dogs weigh about 80 each. Gear and all puts us around 700 lbs. Speed is not an issue, but there is a mile and a half walk over rocks in about 2" of water that is. I was thinking about building the lake buggy hull, but modifiying it to be able to use a 35 hp briggs. That is what I want to know. Is the weight thing doable in a mini, and what type of engine should I get to do it? There is more info here than I have ever seen, so I will need to lean on someone to do it. Cost is a concern, so I will probably looking for a used engine. Tell me what you all think. Appreciate any help towards this and thanks for reading this long post if you made it to the bottom.
rob
rob
