Before you spend a lot of money, get some fine emery cloth
and cut a piece about 1''x2'' fold it in half longways grit side
out and with the points closed ( you may have to turn the
motor ) spread them out just a tiny bit with a small screw
driver slide the emery cloth between the contacts release
the points and sand them lightly, three or four strokes should
do fine ( not to much ) If still no fire, disconnect the wire from
the mag to make sure it's not grounding out somewhere in
your wiring system. If still no fire CALL THE MAN !!!
