Oil Cooler
  • Start date Start date
A
Anonymous
Guest
Does anyone have an oil cooler on their car motor boat?
I think I might add one of the good stacked-plate coolers to mine, and possibly use the hard-blok short fill to add some strength to my 383 cylinders
I'm thinking it should be similar in performance to a 220 GPU if I can get the cam companies to recommend the proper cam.
I can tell you that from personal experience don't pour your block not even a 1/4 inch that is for sure. Any 383 should destroy a 220GPU if it has a gearbox on it. Them 383's are great airboat motors they make great power and torque and the 350 block is more forgiving too mistakes than the a 400 block.
