Thank you very much to those of you who posted info for me.
I checked the oil tonight and according to the dipstick there are about 5 quarts in the engine. I went out for a 30 minute ride with no oil leaking at all. I warmed the boat up to about 230 degrees and again idiling at 20 psi oil pressure. I think the pressure goes up while running to about 40 psi, but I will have to check for sure. After the boat was warm I did notice a small amount of smoke/steam coming out of the breather tube when the engine was reved up. There was also a little white smoke out of one of the pipes when taking off.
Is it safe to run with 5 quarts of oil in the 0 290? This boat has two oil coolers on it if that makes a difference.
I will post some pictures tommorow, thanks again for the help.
